PDAVIET ATOM OS 5.2.2008 build 2000.1.0.0 by Medkid: The Final 6.0
Dùng Advanced settings enable SMS delivery notification.
Coi chừng bồ turn on Wifi nên đèn màu vàng sáng luôn => Tốn pin là phải còn kêu ca gì ???? :-/
Chính xác 100%. Mình cũng từng bị 2 problems trên nhưng giờ ok rồi. Thks Medkid nhé. Có điều mới cài cái PVclock vào tối qua thì thấy pin hao quá. không biết có phải do cái này không?
thanks mr medkid but i need Download thí room what way ples
Downloading, It's your job not mine, mate :O .And this thread is used to discuss about the Rom's bugs only. Please don't ask about downloading again. Thank you.
Use "Advanced settings" to increase cache:
1.choose performances.
2.Increase the values of system cache size and Glyph cache.
This will decrease your device's free RAM, but speed it up a bit
BTW, I think it works good on my device, can you explain more clearly about your problem ? What do you run ? and what do you mean by saying "sluggish" ?
Im running the minimum of settings, nothing on today screen except the date. When i open the Programs folder through the start menu it takes a few secs before it opens and shows the icons. Another thing is that sometimes apps just seem to shutdown on their own, like IE and word, Coreplayer will run for a few mins then shutdown aswell.
the "close" problem was caused by pBar 1.5 ,when you tap x pBar will sometimes close 2 running programs at the same time. I know about this and will remove it on my next rom. But I don't see that it has "auto shutdown" bug as you said. :)
Thank you for your feedback.
Ah ok. How do i disable pBar then?
Well anytime mate, your roms are the best ive seen, professional and sleek. By the way, any chance of putting total commander back in the next rom?
How about WM 6.1 ROM by Medkid ? 6.1 will be my next rom ;). As a gift for all of the members of PDAVIET.net on the Tet holiday in Vietnam and other Oriental countries as well as China. :D
Đây là bản ROM mới 6.1 của mình:
(here it is, 6.1:)
http://pdaviet.net/showthread.php?p=269374#post269374
Heard some rumors about a 6.1 rom, is it microsofts latest release?
Thank's Medkid for your rom .I have same problem like Jujiyass ,but after i disable WkTask & soft reset ,this problem gone . I use pBat1.5 instead,work fine for me
ó o, có ai bị như mình không, màn hình trắng 1 khúc sau khi gọi điện. chỉ còn lại 3 biểu tượng in coming, out going, missed call. reset lai máy thì bình thường. các chức năng không có gì ảnh hưởng. please help!
Tôi mới dùng con O2 XDA Atom Exec và mới bắt đầu up rom thử, Các bác cho hỏi cái rom này có dùng được cho máy của tôi không (chả là sau khi nghiên cứu thấy bản rom này của Medkid hay quá). Cám ơn nhiều!
Bản room này chỉ xài cho ATOM đc thôi bạn àh. K xài cho EXEC được. Cẩn thận, đọc kỹ topic trước khi down room về up, co chừng phải chuyển chức năng của atom từ gọi đt wa làm cục chặn giấy bây giờ.:p
các bác ơi em dùng O2 S đang định up cho thằng bạn dùng Atom Life thì down rom này được không ạ?
mình đã up rom này nhưng nó lại mất cảm ưng rồi không còn định màn hình được nữa,mình đang thử up lại lần nữa xem có bị nữ o?
lần này thì ok rồi thanks medkid nhà mình sẽ tes .lần trức chắc lại máy có vần đề .
muôn dùng FTouchFlo 1.04 thì phải làm sao vậy mấy bác ,trựt muốn chầy màn hình luôn mà có thấy gì đâu nè,sao máy e vào phần sceen để chỉnh màn hình nhưng vô căn lại cảm ưng thì lại mất cảm ưng vậy nhỉ có phải máy có vấn đề o?
Vào FTouchFlo Settings, chọn ngay Done là có thể trượt được rồi. Hoặc có thể chỉnh sửa tùy chọn trong đó cho phù hợp.
Mất chức năng Align screen là do FTouchFlo chạy ngầm. Vào \Windows\Startup\ xóa FTouchFlo.lnk đi rồi reboot.
sao em up xong cái đèn vàng lâu nay nhấp nháy hoài nay sáng luôn , khoảng một lúc lâu mới tắt , mà khi tắt thì wifi tự động bật lên luôn :-?
