[SSPL] HowTo flash cooked OS - Testers needed
Nội dung nó đấy mọi người tham khảo
We need some beta testers here to make this stable.
Beta testing phase only for advanced users; don't want to explain how to flash a ship ROM using the original SPL to your device!
This is an easy way to flash unsigned OS images to the HD2. It should not void your warranty like HSPLs do, because it does not change your SPL. I know for a fact, that repair centers are advised to check the SPL version number on the device.
How save is it?
We disabled SPL and Radio flashing, so it can only flash Splashes and OS images.
(To all hackers out there... don’t enable it! else you will BRICK your device)
Worst case is that you destroy your OS partition, in that case you must flash a ship ROM using the original SPL (Vol down on boot run ruu from PC :D)
We did our best to make it save, else we would not release it for public testing, but anyway, all on your own risk!
How to use it:
  • Download the SSPL_RUU.exe and put it into an empty folder
  • Add the RUU_signed.nbh that you want to flash to your device into the same folder
  • Connect the device to the PC, device must be running WM, not show the 3 color screen
  • Run SSPL_RUU.exe
Done, flashing should start!
*** Watch me doing it *** :D
... btw, my device is still working after using it over 100 times :)
Troubleshooting:
  • If you don’t see USB at the bottom of the device screen and the ruu showed a connection error, disconnect the device and connect it again... USB should be there now.
    Then just run the SSPL_RUU.exe again, flashing will start now
  • If the flashing breaks before 100%, stay cool! ... Reset the device and go to Boot loader, then flash a ship rom to the device (Must be the right rom, with the right CID)
    Don’t forget to report that it happened... after you flashed the original ROM back, you can try again.
  • It is possible, that sometimes the screen stays black for 15sec or more before the SSPL 3 color screen shows, if it takes too long, do reset and try again :( and please report that!!!!
  • "Your OS ROM isn't customized for your hardware. Please reflash the proper ROM code or contact the service center", !!! Problem NOT related to this SSPL !!! ... this means that you flashed a region protected rom... flash back to a ship ROM for your device and stick to ROMs with your region ID... or patch them :D (You might have to remove the battery after flashing back, else it might not boot up)
Link:
Link: View attachment 260802
Thanks for testing!
cotulla and bepe
Tóm tăt nội dung là
Đây là bản Beta để UP ROM HD2 quá trình Up ROM không động chạm gì đến đến Radio và SPL
cách Up
1- copy bản SSPL_RUU.exe vào một thư mục
2- Copy bản ROM vào cùng thư mục trên
3- Kết nối PPC với máy tính ( PPC đang chạy WM không hiển thị màn hình 3 màu)
4- chạy SSPL_RUU.exe
- Lưu ý : Nếu trong quá trình Up ROm bị lỗi thì chạy lại bản ROMSHIP ( bản này ROM phải phù hợp với CID)
---Mọi người phải tự chiu trách nhiệm về rủi ro của mình
- DOWN LOAD VIDEO hướng dẫn ở đây
Big thank cotulla and bepe
P/S Mọi người tự đọc thêm bản gốc nhé, thấy bên xda có vài người trả lời đã Up ROM ngon lành - Mình chưa có HD2 mới có ý định mua thôi đang thu thâp tài liệu để Up và Cook :-?
