UP ROM, HardSPL cho BLACKSTONE (OLD)
minhsu
<img src="images/pvRanks/VipMem.gif" alt="" border
UPROM BLACKSTONE (TOUCH HD)
OliNex đã hướng dẫn Uprom Blackstone, hãy xem tham khảo tại đây:
http://forum.xda-developers.com/showthread.php?t=431217
UPDATE: Hard-SPL released!
many thanks to testers for testing!
Preparations:
0) this package is for Blackstone devices. for BLAC100 so far (SSPL loader checks this), if your ModelID is different, contact us for testing!!
1) make sure you have .NET framework installed on your PC! if not, get it from http://www.microsoft.com/downloads/d...DisplayLang=en
2) if you have vista, WMDC update is recommended: http://www.microsoft.com/windowsmobi...ce-center.mspx
Instructions:
1) download Hard-SPL package from attachment, extract to an empty folder.
2) you must Have Phone Synced with PC in Windows Mobile!!!
3) run HardSPLWrapper_Blackstone.exe on PC, make sure it's launched from a local drive (not through network drive, etc.). if you are on vista, launching as Administrator is recommended,
4) follow steps in the RUU, check device for prompts after PC shows loading bar, press Yes on phone if asked.
5) some notes: when RUU says it will hard reset, do not worry, it is not going to do that. also when it says the flash will take 10 minutes, ignore that, it will only take a minute or so.
6) device should go to a tricolour screen now that says 1.07.OliNex, the SSPL version, which is temporary.
7) in a bit unusual way, it will take a few seconds for the RUU to detect the device, but do not worry, as soon as the "USB" text on the tricolour screen shows up, RUU will see device.
8) SPL flashes, device automatically reboots, job done.
9) to confirm you got it installed, go into bootloader mode (tricolour screen!) and verify the screen shows 1.14.OliNex, which is the Hard-SPL version.
NOTE: you will not see the SPL version during normal boot, that is the OS version, not SPL!
to enter SPL to check version, fully power the device off by long press of power key, then power on while holding the "volume down" key on the left side of the device. keep holding the volume down key until you see tricolour screen which is the bootloader mode, then release it.
NOTE 2: anyone having problems with the device entering SSPL automatically, please copy SSPL-Manual-TouchHD.exe from SSPL-Manual-TouchHD.zip attachment to the device and run it. then once the screen is sayingn 1.07.OliNex, run RUU manually. i.e. you launch the Hard-SPL RUU (HardSPLWrapper_Blackstone.exe) on the PC and flash.
NOTE 3: this is unsigned Hard-SPL. no limitations on flashing ROMs or radio packages. also, this has overwrite protection against HTC RUU's overwriting HSPL with a stock one, so if someone needs to revert to stock SPL for warranty reasons, a stock SPL downgrade package is posted in this post as well. use this relocker *only* if you need to return the phone for warranty, and only use it as last step - after reflashing stock OS and radio.
NOTE 4: do not use this RUU for anything other than SPL flashing (i.e. hardspl or stock spl restore)!!! nothing other than SPL's made by Olinex team (using OliNex custom cert) will flash to make SSPL more secure. if you want to flash some other rom, then use shipped RUU or blackstone customRUU if you need to flash cooked ROM.
NOTE 5: for developers asking: Hard-SPL is not based on MFG SPL, as that SPL causes the screen not to turn on after a resume. (maybe solved one day ). so currently, MFG SPL can strictly be used for development and hacking.
Troubleshooting:
- read the instructions above.
- anyone having problems with the device entering SSPL automatically, please copy SSPL-Manual-TouchHD.exe from SSPL-Manual-TouchHD.zip attachment to the device and run it. then once the screen is showing 1.07.OliNex, run RUU manually. i.e. you launch the Hard-SPL RUU (HardSPLWrapper_Blackstone.exe) on the PC and flash.
- if you get connection error in RUU after the device goes to 1.07.Olinex screen, then try a different USB port, also do not use USB hub, you can also try rebooting your PC, and can try using another PC. also you can try unticking advanced network functionality in start menu / settings / connections / usbtopc applet.
- if SSPL-Manual.exe or Enterbootloader.exe fails to run (says missing component or similar), try a hard reset of the device.
- USB or connection error: as already said, in a bit unusual way, it will take a few seconds for the RUU to detect the device, but do not worry, as soon as the "USB" text on the tricolour screen shows up, RUU will see device. if not (happens very rarely), wait for RUU to time out (or wait 5 minutes). then remove back cover, reset, it will boot OS again, then you can retry unlocking process from step 1.
- USB or connection error: alternatively, launch SSPL-Manual.exe from attachment, run it, wait until 1.07.OliNex tricolour screen says "USB" on it, then run the HardSPLWrapper_Blackstone.exe on the PC.
Attached Files Unsigned_HardSPL_for_Blackstone_OliNex.zip (1.12 MB, 0 views)
Copy nguyên từ WiKi về, không có hướng dẫn TV không nên !!!
Quá đã, vừa xem ở xda-developers.com
Tiếc là máy mình vừa bị nứt màn hình, đang chờ sửa chữa, mà không biết sửa ở đâu, hỏi VN thì chưa có, không biết bên Singapore có màn hình để thay ko nữa. Bác nào có thông tin chỉ nhé
Chờ cả mấy tuần nay để chuyển từ tiếng Đức (người nhà mua nhầm) sang tiếng Anh, giờ có thì lại bị hư, uổng thiệt
Sau bao ngày chờ đợi, cuối cùng OliNex cũng đã cho ra công cụ HardSPL cho Touch HD (dòng Blackstone).=D> Mình cũng vừa cài xong và up lên bản rom khác (tất nhiên là bản zin vì giờ này vẫn chưa có bản cook nào cả). Quy trình thực hiện việc cài HardSPL như sau:
1- Giải nén và copy vào một folder mới.
2- Kết nối HD với máy tính và chờ icon màu xanh ngừng quay.
3- Chạy HardSPLWrapper_Blackstone.exe trong folder vừa tạo. Thực hiện các bước theo chỉ dẫn trên màn hình máy tính.
4- Trên màn hình HD sẽ hiện một window nhỏ, bạn chọn ‘Yes’
5- Màn hình HD sẽ chuyển qua 3 vạch màu với các thông số 1.07.OliNex
6-. Sau khoảng 1 phút quy trình cài HardSPL sẽ được hoàn tất.
7- Để kiểm tra máy, bạn đưa HD về chế độ bootloader bằng cách: tắt HD hoàn toàn, giữ phím Volume down và ấn rồi buông phím Power, bạn sẽ thấy 3 vạch màu. Nếu bạn thấy thông số 1.14.OliNex có nghĩa HD đã được cài HardSPL.
Giờ đây bạn có thể up rom hoặc radio nào đó cho HD của mình!!! =D>
Tham khảo và tải về: http://forum.xda-developers.com/showthread.php?t=431217
Mình vừa up bản RUU_BlackStone_HKCSL_WWE_1.19.831.0_Radio_52.49a.2 5.26_1.09.25.14_Ship thay cho bản zin 1.14. Các bạn có thể tải bản 1.19 này từ đây: http://rapidshare.com/files/17297734..._Ship.exe.html
Cám ơn, tuy nhiên cần đưa link tải cụ thể, không nên đưa link như vậy.
Topic khóa và đổi tên.
Nâng cấp ROM, Hard-SPL cho HTC Blackstone [HTC T828X / HTC Touch HD]
Sau bao ngày chờ đợi, cuối cùng OliNex cũng đã cho ra công cụ HardSPL cho Touch HD (dòng Blackstone). Mình cũng vừa cài xong và up lên bản rom khác (tất nhiên là bản zin vì giờ này vẫn chưa có bản cook nào cả). Quy trình thực hiện việc cài HardSPL như sau:
Tham khảo: http://forum.xda-developers.com/showthread.php?t=431217
MẸO: do lỗ RESET của HD nằm trong lưng máy nên sẽ rất bất tiện nếu sau mỗi lần up rom phải HR (bằng cách mở nắp pin, chọt lỗ và giữ 2 phím lên-xuống của Volume) hoặc chờ máy hoàn tất configuration rồi HR bằng cách 'Clear Storage' (mất khoảng 10 phút), mình có cách này rất nhanh: Bạn phải chú ý khi quy trình up rom thực hiện gần đến 100%. Khi quy trình này hoàn tất màn hình sẽ chuyển đen, ngay lập tức bạn giữ cả 2 phím lên-xuống của Volume và chờ vài giây máy sẽ hỏi việc thực hiện HR rồi bạn chọn phím lên của Volume là xong.
Một vài bản rom tiêu biểu:
[ROM][WWE][17.12.08][CE OS 20764] 1.19.831.0(25581) -=® panosha ® =- Black Pearl 1.0
Bản này khá gọn do tác giả bỏ bớt các ứng dụng k cần thiết, tốc độ tốt và pin dùng lâu. Về độ ổn định thì mình cho rằng cũng khá ổn tuy chưa test được lâu! [Stick Out Tongue]
Download
