[03 JUNE][[MAGLDR/cLK] LeoRCMix S v.1.5 (RCMixS v.2.0) [Sense 2.1+3.0][Tytung R10]
Nguoi_Nhen
LeoRCMix S v.1.5 (RCMixS v2.0)
Ace S 2.36.405.8 WWE, Android 2.3.3
by Klendelrus (XDA)
Tham gia lâu nhưng chưa post gì . Bài này cũng chẳng hay ho gì chỉ là copy bài của mem XDA nhưng test và cảm nhận thấy bản ROM này ổn định mượt , cài đặt dễ dàng boot vào nhanh hiển thị thời tiết khá tốt Lock sceen ít giật hơn nên giới thiệu cho các bạn
Nguồn: http://forum.xda-developers.com/showpost.php?p=14230248&postcount=1
What's working:
  • Phone
  • Wi-Fi
  • Bluetooth
  • FM radio
  • SD card mount
  • Camera
  • Weather
  • Lockscreen with transparent icons (thanks snq-)
What's not working/bugs:
  • Graphic glitches
  • Power menu works only one time (use included app Quick Boot)
  • Tethering?
  • Camcorder
  • you tell me
Features:
  • Ace S 2.36.405.8 WWE, Android 2.3.3 base with Sense 2.1
  • Multilanguage
  • Sense 3.0 Lockscreen with transparent icons (thanks snq-)
  • Sense 3.0 SMS/MMS application
  • Sense 3.0 USB Menu
  • Sense 3.0 Streak and Weather Live Wallpaper (preview not working, apply directly)
  • Sense 3.0 Task manager (even in quick settings)
  • Settings.apk with system, data and ext partition info (thanks m0narx)
  • All widgets/themes from HTC Hub
  • CM-style screen on/off animations
  • Option to enable stock android lockscreen
  • HTC Touch Input with arrows
  • Some useful apps preinstalled
  • and more
Tips:
  • Be advised: Sense 3.0 Lockscreen can be buggy, give it time to settle
  • To save some battery, change the wifi power settings.
  • To make the battery last longer, turn off pocket mode in settings/sounds.
  • Always choose Shut down instead of Reboot option, because reboot may cause data corruption (versions with Rafdroid 1.9 kernel)
Cài đặt: MAGLDR 1.13: EU and TMOUS: 200M system + 1GB EXT partition
MAGLDR_LeoRCMixS_v1.5
[DOWNLOAD]http://www.multiupload.com/3DM63E92JD[/DOWNLOAD]
[video=youtube;kWvm5R38EzU]http://www.youtube.com/watch?v=kWvm5R38EzU&feature=player_detailpage[/video]
Cập nhật các bản rom LeoRCMixS Series của tác giả Klendelrus từ XDA (Thanks Klendelrus) đã chỉnh sửa phù hợp với VN:
- Bản MAGLDR_LeoRCMixS_v1.2_VN: http://www.multiupload.com/F4JMHSHD8W
- Bản cLK_LeoRCMixS_v1.4_VN: http://www.multiupload.com/MTS30PK23Y
- Bản MAGLDR_LeoRCMixS_v1.5_VN: http://www.multiupload.com/U9I9Q3LODI
- Bản cLK_LeoRCMixS_v1.5_VN: http://www.multiupload.com/FLY1CTIX2Z
Thông tin:
- Tích hợp thêm Tiếng Việt & Font hiển thì Tiếng Việt chuẩn.
- Bỏ hết các ứng dụng ít dùng và ngôn ngữ (chỉ để lại Tiếng Việt, Tiếng Anh và Tiếng Nga).
- Thêm RootExplorer & Bộ gõ Tiếng Việt.
Đóng góp bản rom của tác giả này mà mình đã Edit lại, thêm Tiếng Việt, bỏ hết các ngôn ngữ chỉ để Tiếng Anh, Tiếng Việt, Tiếng Nga, bỏ hết các ứng dụng thừa ít dùng tới, thay đổi font chữ hiển thị Tiếng Việt chuẩn,...
Bản MAGLDR_LeoRCMixS_v1.5 bạn nào có nhu cầu mình sẽ edit và đưa lên sau...
Em đang dùng bản này, thấy rất OK nhung em chưa flash bằng cLK bao giờ, bác có thể edit bản MAGLDR sớm chút được ko?
Bản này T-mous không nhận đủ ram , nó chỉ nhận có 512 Ram thôi vậy mới chết chứ :(
Chạy android trên HD2 chỉ nhận 512Mb RAM thôi bạn ạ. Chừng nào các tác giả hoàn thiện Bootloader MAGLDR hay cLK thì mới có được 576Mb như WinMo
Bạn Nguoi_Nhen hãy edit thêm tên tác giả hoặc nguồn để tránh bị hiểu nhầm.
Đã Edit và thêm thông tin lại...
@ All: Các bạn post rom lấy nguồn ở đâu thì ghi rõ tên tác giả và nguồn của bản rom nhé, bản quyền mà... Lần sau mà gặp những topic rom thiếu tác giả, nguồn thì sẽ xóa thẳng tay đó.
Cho cách em cách hướng dẫn cài đặt luôn nha bác, em xài HD2 512, bản này có bị Cash màn hình không bác
Vẫn bị chứ làm sao fix hết được. Bản này thì CWM 200M + EXT 1G... Bạn sang topic HƯỚNG DẪN SỬ DỤNG HD2 NAND TOOLKIT [ALL IN ONE] tham khảo cách cài MAGLDR Recovery... Còn phân vùng thẻ thì bạn dùng luôn Recovery mà phân vùng, vào Menu Recovery, chọn Advance ->Patition SD Card -> Chọn 1024M -> Chọn Swap là 128M là được... Chú ý là khi phân vùng nó sẽ format thẻ nhớ đó bạn nhé...
Cập nhật link bản MAGLDR_LeoRCMixS_v1.5_VN đã edit trên post 1. Bỏ hết các ngôn ngữ (chỉ có Tiếng Việt, Tiếng Anh và Tiếng Nga) và ứng dụng ít dùng, thêm Tiếng Việt và font hiển thị Tiếng Việt chuẩn, RootExplorer, bộ gõ Tiếng Việt...
bản cKL down tối wa Up ok, cap nhat thời tiết, gmail vô tư. sáng nay định lướt Web một tí thì không vào được (sim vẫn dùng từ trước đến giờ, Vịt teo sóng sánh tốt tiền còn nhiều) ko hiểu thế nào nữa................ !
Cám ơn đồng chí nhiều !!!! (Sao không có nút Thanks nhỉ :( )
e Recovery 250m mà sao up không đc bác ơi? cần tạo 1GB EXT partition trước không bác? e mới tham gia nên chưa rõ lắm! mong bác giúp đỡ!
