alexnguyen6688
(Android 4.0.3) ICS [ICS MOD 2 BETA 6.3] [CAM] [FB SYNC] [PAID APPS]
by michie (xda-developers)
Tình hình là mình vừa xem bên xda thấy có rom 4.0.3 ngày vừa chụp và quay được, share cho mí bác test thử , có j bỏ qua cho em nhé.
Nguồn: http://forum.xda-developers.com/showthread.php?t=1417472
Hello, here you can find my ICS 4.0.3 rom ported from the n1/desire to run on our HD2s! (Thanks to texasice and Sandvold).
Hình ảnh minh họa:
Included in base rom :
- Phone
- Audio (firesnatch and texasice)
- SMS
- Data
- Wi-Fi
- Bluetooth
- GPS and AGPS (tytung and qwerty_7564)
- Touchscreen
- Vibration
- Charging
- All sensors
- Wired earphone/headphone (zivan56)
- Data usage (i.e. Network Stats and Quota) (tytung.)
- Hardware Acceleration OpenGL (rapmv78)
- Hardware Acceleration OpenMAX codecs (ankuch)
- Software video codecs (ankuch)
- Hardware codecs (rapmv78))
- Camera (BETA) (rapmv78)
- Camcorder (BETA) (rapmv78)
- USB Mass storage (Tytung)
Extra features in ICS MOD 2
- A2SD
- N1/Desire HW hack
- Facebook sync
- Market fix for paid apps
- 3-way lockscreen
- Gapps
- Maintenance + performance script
- Extended notification features
- Lockscreen + notification control app (Evervolv)
Thanks to:
Cotulla, Tytung, Ankuch, Sharky153, drewis, Chaosz-X, DJ_Jedi, Nikez, Raphael, SamStorer, Chichoko, Vaporizer, andreigherghe, Tristan202,
fused, rootSU, Tafkardarso, gubacsek, coutts99, Bexton, Phantom, Sandvold, dk_zero-cool, ...
BETA 6.3
Features :
- Density changed for nicer look
- Hacked market that accept other densities
- Fixed most of the lags
- Modified trebuchet launcher with all its settings
- Updated A2SDGUI
- Added back filemanager
- A2SD :
A2SD : Script modified by me so that A2SD will be auto installed with the rom with correct permissions, zipaligned, ... without lags in rom.
A2SD GUI is included in the rom for use with the script for checking SD-EXT diskspace and various other options (build in android system info will only show internal memory).
Your device may reboot couple of times first boot to complete mounting of SD with A2SD installation.
BEWARE, MOVING DALVIK TO EXT MAY CAUSE THE LOW SOUND BUG TO APPEAR. IF THIS IS THE CASE, UPDATE A2SDGUI APP IN THE MARKET AND MOVE DALVIK BACK TO INTERNAL MEMORY
Download For MAGLDR - Partition size 200/10 :
http://www.mediafire.com/?631szeeo13sqoee
Download For MAGLDR - Partition size 200/10 without A2SD install :
http://www.mediafire.com/?e2q97tjeh6j5qs1
Clk users flash Tytungs ICS Clk kernel afterwards (Thanks Tytung) :
http://nexus-hd2.googlecode.com/file...cLK-update.zip
For softkeys :
ENABLED : http://www.mediafire.com/?t0ewl9m6tjidenq
DISABLED : http://www.mediafire.com/?co8og15xdvn2cto
HISTORY
BETA 6.2
- Camera Panorama mode works (but colours is off) rapmv78
- Fixed DSP manager issues
- TTS Fixed
- Gallery should work better
- Autobrightness should work better
- Gapps updated (4.0.3 calendar)
- Changes in airplanemode functionality
- Market fully working
- Missing google maps permissions added
- Ad hoc wifi support
BETA 6.1
- Fixed no data bug (6.1)
- Added ICS Blurry MMS fix (6.1)
- Added DSP manager (6.1)
- Went back to tytung kernel for this release because of probs with Fhasovic's
- Updated to new N1/Desire sources
- Created all in 1 script for maintenance + performance tasks at boot
- General wifi fix
- Added CRT screen off animation
- Added smooth scroll framework fix
- Lockscreen: can choose whatever you want for the actions in evtoolbox
- Updated evtoolbox : lockscreen stuff
- New feature : interface in ectoolbox with tbwake toggle, vol wake, vol music contols moved here.
- New feature : sixbar signal toggle in evtoolbox statusbar menu
BETA 5.2.1
Features :
- Fixed BETA 5.2 bugs
- Updated kernel, fixed wifi etc here
- Added kernel modules
- Camera/video fix
- New GAPPS
- Added the startup setup
- SU + a2sd working, type a2sd install in terminal after giving root perm (dont forget to fix permissions after moving dalvik, apps to ext)
- Fixed wifi strength icon (Beta 5.2.1)
BETA 5.1
Features :
- Added fhasovic r1.20 + kernel as default
- Added a2sd script back, you can control in terminal or a2sd gui from the market
- Updated hardware encoder support (rapmv78)
- Camcorder working, still in beta (rapmv78)
BETA 5
Features :
- 6 barsignal: new drawables
- launcher2 : a couple options like hide search bar (There are a few options in the launcher settings that dont do anything yet, the only working opiton is hide search bar)
- extended notification features (Tap settings icon in notification bar to switch between features, long press settings icon to open settings)
- Updated EVToolbox for controlling lockscreen/notification menu
- lockscreen: control music with volume buttons feature
- Lockscreen: (choice between tab and rotary style, default is 3way ics style.)
BETA 4.3.1
Features :
- Added file manager
- Cleaned out the rom
- Speed up the system
- GPS fixed (In rom 4.3.1)
