alexnguyen6688
apdate BETA 6.3 dùm chủ thớt
Features :
- Density changed for nicer look
- Hacked market that accept other densities
- Fixed most of the lags
- Modified trebuchet launcher with all its settings
- Updated A2SDGUI
- Added back filemanager
- A2SD :
A2SD : Script modified by me so that A2SD will be auto installed with the rom with correct permissions, zipaligned, ... without lags in rom.
A2SD GUI is included in the rom for use with the script for checking SD-EXT diskspace and various other options (build in android system info will only show internal memory).
Your device may reboot couple of times first boot to complete mounting of SD with A2SD installation.
BEWARE, MOVING DALVIK TO EXT MAY CAUSE THE LOW SOUND BUG TO APPEAR. IF THIS IS THE CASE, UPDATE A2SDGUI APP IN THE MARKET AND MOVE DALVIK BACK TO INTERNAL MEMORY
Download For MAGLDR - Partition size 200/10 :
http://www.mediafire.com/?631szeeo13sqoee
Download For MAGLDR - Partition size 200/10 without A2SD install :
http://www.mediafire.com/?e2q97tjeh6j5qs1
Clk users flash Tytungs ICS Clk kernel afterwards (Thanks Tytung) :
http://nexus-hd2.googlecode.com/file...cLK-update.zip
For softkeys :
ENABLED : http://www.mediafire.com/?t0ewl9m6tjidenq
DISABLED : http://www.mediafire.com/?co8og15xdvn2cto
thanks bác rất nhiều đang chờ mod đổi lại dùm tiêu đề, mà mí nay hem thấy mode qua
