bạn có thể chi rõ cắch thay kernel cho mình biết kô, mình tải về giải nén ra mà co thấy cái file .txt nào đâu? thanks ban trước nha!
INSTALLING THE KERNEL
The following is how I install the kernel, though this requires a compatible build. If this does not work, consult the URL above.
1. Restart phone via the Power menu (or shutdown if you don't have Restart option)
2. Once it vibrates eject microSD card
3. Place the card in your PC reader
4. Copy the zImage and root folder in to the Android folder on the SD card via PC
5. Optionally copy in haret.exe and initrd.gz to the same folder
6. Edit your startup.txt to make sure the KERNEL is using the zImage
The relevant line after editing in my startup.txt looks like this:
set KERNEL zImage
6. Put SD card back in and reboot WM
7. Boot Android (in my case via a bootloader, but you can manually run CLRCAD.exe followed by haret.exe)
----OPTIONAL----
If your WiFi does not work you may not be using a compatible build so try the following:
8. Connect the phone to PC via USB and use Android Commander to copy the modules (bcm4329.ko & tun.ko) to /system/lib/modules
9. Run a script via GScript Lite with the following contents:
chown system.system /system/lib/modules/*
chmod 755 /system/lib/modules/*
10. Toggle Airplane mode on/off
11. Using Android Commander (or again your method of choice) copy lights.htcleo.so from the root/system/lib/hw folder to /system/lib/hw (you may need to rename it, see below)
> Originally Posted by memin1857
I talked to gauner1986 (author of the new lights file) and the filename comes from the /system/build.prop file.
It is the ro.board.platform=xxxxxx line in the build.prop file.
xxxxx is also your lights filename. (lights.xxxxx.so)
For example my desire hd build has msm7x30
others I have seen are htcleo, default, qsd8k, ace, bravo.
So you have to rename the lights.htcleo.so if you want it to work.
đây bạn này nhưng bây giờ có bản 8.5.3 rồi
