JAF version 1.98.62
Detected PKEY: 9000AAC9
Card life counter: 99.99%
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.1.36.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-504\
Searching for default location of ini...
Checking path: \Products\RM-504\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_40.0.003_prd.core.C00
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_40.0.003_prd.rofs2.V05
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_40.0.003_C03_prd.rofs3.fpsx
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_32.0.007_001_000_U002.uda.fpsx
Languages in ppm: English,German,Hungarian,Ukrainian,Russian,Romania n,Bulgarian
Detected P-KEY: 9000AAC9
Init usb communication...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using èGÈ012.005
Elf2flash 09.11.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
....................Loader Sent!
Stage 2 starting..........PUBKEYS already sent...
.......Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 633, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_40.0.003_prd.core.C00...
Erasing cmt zone 00040000 - 00082FFF ... Erase result: 0000
Erasing cmt zone 00083400 - 003FFFFF ... Erase result: 0000
Erasing cmt zone 00400000 - 007FFFFF ... Erase result: 0000
Erasing cmt zone 00800000 - 00D5FFFF ... Erase result: 0000
Erasing cmt zone 00D60000 - 09E5FFFF ... Erase result: 0000
Partition result: 0014
Processing C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_40.0.003_prd.rofs2.V05...
Erasing cmt zone 02FA0000 - 09D5FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_32.0.007_001_000_U002.uda.fpsx...
Erasing cmt zone 09E60000 - 0F71FFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
Sending CMT HASH for SOS*UPDAPP
Sending CMT HASH for SOS*ENO
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS*ISASW
Sending CMT HASH for SOS+CORE
Sending CMT HASH for SOS+ROFS1
Sending CMT HASH for SOS+ROFS2
Write result 27: 1701
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
Phone not found...
Second try...
MCUSW: (null)
APESW: (null)
VariantSW: (null)
Prodcode:
Setting test mode...
Failed! Aborting!
Done!
jaf bản cfw nào củng bị vậy... ai cứu em với.... :(:(
Cần giúp up FW Nokia 6760 Slide RM-573 (Lần đầu tiên làm)
Đã dow đc bản fw thích hơp rồi! Nhưng không biết làm sao hết! Ai hướng dẩn mình đc ko ? có than khảo qua JAR rồi mak ko hiểu j hết ! huhu
JAF version 1.98.62
PRESS POWER ON NOW!
Using èGÈ012.005
Elf2flash 09.11.000
CMT RAW loader...
Status byte: 8000
Result: 0000
Erasing cmt...
Send CMT CFG...
Writing cmt...
Rebooting...
Restarting CMT...
Pooling phone...
Phone not found...
Second try...
MCUSW: (null)
APESW: (null)
VariantSW: (null)
Prodcode:
Failed! Aborting!
Done!
bạn phải dùng fw khác thôi... fw down trong navi ấy... và phải cao hơn bản bạn đang dùng
có anh nào co0k cho em một cái fw cho 5230 vsss hixx em đang dung 5230 RM-588 V 51.6.2
Cần được giúp đỡ
http://www.mediafire.com/?5vs7ufblhlrnt38 (nguồn http:// bbs.dospy.com/
viewthread.php?...9&bbsid=193)ai ra tay thêm ngôn ngư vào bản cook
fw 6120c RM-243 v7.10 này được
không em thêm vào thì khi thay đổi
ngôn ngữ thì ko boot được , đã thử
nhiều hướng dẫn trong diễn đàn.
Em rất mong nhận được sự giúp đỡ.
cần các bác build firmwar giúp
mình cần các bạn build firmwar của máy n73 ME giúp đỡ add thêm ngôn ngữ viết tiếng Việt vào.
nếu ai làm được cho mình xin về với. thanks nhìu
hoặc nếu tốn nhìu tg thì chỉ mình xíu để mình tự làm cũng được. thank
xin cfw e66!!!!
pro nào có cho em xin với?????em tìm hoài mà chẳng thấy...híchic.......hoặc pro nào tốt bụng mod cho em một bản cũng như ace dùng e66!!!!!!
phone not found
sao em hack phone bằng JAF thì toàn báo phone not found mặc dù đã cài pc suite và các phần mềm khắc ,từ lúc mua máy em chỉ JAF đc 1 lần còn lại là toàn báo phone not found bác nào biết cách nào chỉ em với :(
mọi người cho mình hỏi với. Mình đag dùg win 7 x64 bit. cài đc JAF rồi. nhưg lúc tích vào cái ô USE INI thì nó hiện luôn ra 1 cái bảng mới, mà cái bảng này chẳng có dòng nào để chọn ý cả, vậy tức là sao ?
cho mình hỏi thêm chút nữa. cắm usb đt - máy tính thì có cần bật PC Suite lên ko ?
mình cài lại vào Program Files thì chạy đc cái đó rồi. Nhưg mà sao ko thấy có RM-559 nhỉ
mình dùg nokia X6 RM-559. Nhìn ko thấy có trog bảng đấy @@
Bạn kiếm files " jaf_nok4models.ini " khác, rồi copy đè vào " C:\Program Files (x86)\ODEON\JAF"
rồi chạy lại JAF thử coi \-/
tình hình là em không jaf được n85-1 tắt nguồn gắn vào nó sạc pin hoàn không biết jaf sao nữa để nguồn thì thi jaf tới nó chạy vài dòng thi đứng luôn. nhờ các bác chỉ giáo;;)
xin fw e71 bản mới nhất.có hack sẵn
như tiêu đề có bác nào có fw e71 RM-346 có hack sẵn thì share cho e nha.hoặc file hack cững được em đang cần gấp
HELLP XIN RM NÀY
có ai tải được RM này của tàu chưa cho mình xinh với nếu không có thì nhờ ace nào biết tải giúp mình được không toàn tiếng tàu mình mò mấy ngày rồi mà không tải đươc thank
link của nó đây:http://bbs.dospy.com/thread-13214034-1-275-1.html
Pro cho xin file RM và File Pat của E75 Fw 211.12.01
Pro nào có sẵn file hack của E75 fw 211.12.01 cho mình xin! thank các bạn.
Các bạn cho mình hỏi, em 5530 của mình flash = jaf khi tới chỗ search phone mình bấm nút nguồn thì jaf chẳng nhận đc, làm lại mấy lần rồi lần nào máy cũng mở nguồn luôn chứ jaf ko nhận,
còn flash dead = phoenix thì nó bảo thiếu file 5530_SW_0634766_SEAP_2G_3.0.fpsx ..., mình đã dow đủ các file trên navifirm về mà chả thấy có file này, ai giúp mình với
đầu tiên mình có 1 số câu hỏi nhưng ko biết hỏi ở đâu nên đành hỏi ở đây ,nếu có nhầm lẫn gì xin thông cảm dùm :p
mình xài con n5233 ,trước đây đã cook lên bản c6 giờ muốn flash lên bản cfw khác nhưng chả biết có làm chết máy ko
với lại kể cả khi định flash bản cfw khác thì cái jaf nó lại bị lỗi ko tìm dc file ini =)) mặc dù đã tải file ini có hỗ trợ cả fw của n5233 lẫn c6 ,mà cũng ko biết có phải tại bản jaf ko tại vì mình xài bản jaf 1.98.62 (đã crack sẵn) vì bản tải trên forum ko dùng dc (cũng là 1 vấn đề cần hỏi) vì khi cài nó bị lỗi liên quan đến file winscard.dll ,mặc dù cài xong thì đến cái file pkey cũng lỗi thiếu file dll nốt =))
à còn nữa ,cái jaf mình đang dùng mặc dù báo lỗi not found ini file nhưng vẫn mỡ dc file ini nhưng tội cái là chả có dòng nào để chọn với lại cái bản fw vietnamese gì gì đấy (xin lỗi tác giả vì lỡ quên tên) giải nén ra chỉ có 1 file ,file đó chỉ mỡ dc = nút PPM ,vậy chỉ cần vậy là flash dc rồi à ? ko cẫn mấy cái nút kia sáng phải ko ???
hy vọng mấy bác quan tâm và trả lời mấy câu hỏi nhỏ này
bác nào có bộ wlan chạy ổn định cho mình xin với, CFW của mình bị hỏng ko sử dụng wifi dc! mình xài x6! tks
xin FIRMWARE N82 bản Cook mới nhất
;;) nhìn đang muốn up lại cái N82 ai có bản Cook nào cho mình xin tích hợp sẵn hack vĩnh viễn nha :ar!
Help! Điều kiện để chạy hđh sym
Các bác cho em hỏi:em có 2 kon nokia 300 và 302.Cả 2 đều có chip 1ghz.Ram 128mb và vàj trăm mb bộ nhớ tr0ng.Thật ức chế khj cả 2 k0n đều là s40.Liệu em có thể đem hđh sym s60v3 chạy cho 2 k0n này k0?
