WM 6.5 build 23004 Titanium Neo Shadow PDA Viet Special Edition
wapvirus
New Colour TaskBar
HTC Claculator 1.5
HTC Comm Manager v2.7.5.0
HTC MP3 Trimmer 2.0
HTC Camera Album 2.5
PCMKeyboard 1.4 Vietnamese QWERTY
Safe Inbox Extender
Solitiare Graphics updated
Mobile Office 2007
Mobile Word
Mobile Excel
Mobile Power Point
Advanced Config 3.3 by Julien Schapman
HTC X Button
WinRar 3.80
WM Storage 1.9 by Igor v Bozhko (Two Way)
PHM Reg Edit 7.0 by Philippe Majerus
Fexploreext 2.05
PimBack-up 2.8.0.0 by FdcSoft
Synchro Time 0.95 by Dennis Grachov
Talking Sound Events
Netframework 3.5
Task Manager 3.1 by FdcSoft
MoDaCo NoData 2.0
SmartLock 1.7 WWE
Birthday2Calendar
CHome Editor v1.6 by showaco
ATContacts v0.98 by greatbal
tommy34 LockScreen
Titanium Shadow Neo Skin Now with more Supported panels/plugins:
1) CMyPhotos
2) CMusic
3) ATFavePeople
4) TitaniumWeather
5) CPhone
6) CText
7) CClock
8) CAppointments
9) CEmail
10) CVoicemail
11) Favorites
12) CLauncher
Make sure you read this first or your Titanium Neo Shadow wont look like the screenshots
1/Goto settings\Today\Apperance Select Rock and Republic Black theme and press ok
2/Goto Start\Utilities folder and run ChomeEditor (Enable ATFavePeople plug in)
save then exit
Thanks again to Lamson
Thanks to greatbal For his Titanium Shadow Neo Skin
Thanks to blazingwolf For help packaging Neo
For those who use Titanium Weather this version is made to go with Neo
http://forum.xda-developers.com/attachment.php?attachmentid=197644&d=1245509993
Around 20mb free Ram with Titanium G4
Around 44mb free Space + 10mb Extended ROM G4
Download Here:
http://www.mediafire.com/download.php?jrzlhuuyzjk
Mirror Download:
http://www.adrive.com/public/39e9ffcd1c7432e618641423db84fe3bb2d7eab94bdfe6cbbd2f9825aff17b1f.html
Problem: ! CRC failed in nk.nbf. The file is corrupt, I downloaded 2 times but the have same problem.
Can you upload again?
thanks for Nice rom. But I don't like button Xclose is red. help me change for white like defaus. Thanks.
Thanks wapvirus for this Rom. I know you are also member of XDA Developers as i. Thanks again. شکریہ
yes it`s nice rom but i face some problems with thí róm:
1- the touch is really slow kind of reponse í little slow
2- the MMS option í not appear on sms
3- i face many errors when i active somethings like CHome and favourite people
First of all i would like to thank you all for your kind replys i hope you enjoy this ROM and i will listern and try to help solve all problems ;)
To Fix Touch Response you must edit the following registry string
Mã:
[B][HKEY_LOCAL_MACHINE\ SYSTEM\GWE\Touch\ Filter][/B]
"MinimumTapTime"=dword:28 ; 40ms minimum touch time
[B]set this as 0 and restart your device[/B]
Arcsoft MMS Composer to add MMS support or similar :
DownLoad Here :
http://forum.xda-developers.com/attachment.php?attachmentid=196936&d=1245332794
Use Chome Editor and only enable the list below only these plug-ins are supported Disable the others , Save layout then exit Chome editor and all should be working ;) ( Chome editor í in the Utilities folder )
1) ATFavePeople
2) CMusic
3) CMyPhotos
4) CMusic
5) CPhone
6) CText
7) CClock
8) CAppointments
9) CEmail
10) CVoicemail
11) Favorites
Good Luck :)
Yes i know there is a problem with the taskbar hook for battery and i don't know the solution sorry
cho mỉnh hoi? tý khi giai? nén file rom co foder vitas divers lả đê? lảm gỉ vậy
excuse me, how can i attach large photo to my contact which showed at "fave contacts" .the photos too small. thanks
If you add the photo to your normal wm contacts then add the contact to ATContact the photos will show large ( if you are still having problems or i didn't describe the solution well please post here again and i will help )
