WM 6.5 build 23004 Titanium Neo Shadow PDA Viet Special Edition
i don't know how large your photo contact is and how it looks? could you post it for me.. thanks
is it ATFavepeople? i am using yr kool rom. :) .may you give me your yahoo messenger id ?
Very sorry i don't have yahoo only MSN :)
Please try the following :)
Goto Start\Utilities folder and run ChomeEditor
A list of availible Plug-ins will appear
Enable only the following supported plug-ins
1) CMyPhotos
2) CMusic
3) ATFavePeople
4) TitaniumWeather
5) CPhone
6) CText
7) CClock
8) CAppointments
9) CEmail
10) CVoicemail
11) Favorites
Disable all the others in the list ie.. welcome widget,luancher,blah blah, blah,
Save the layout with the save button
press exit and Neo will refresh showing only the plug-ins you have selected
Goto the Favourite contacts tab on Neo and you should see a add contacts select this and start adding your contacts :)
This plug-in will automatically resize your images to fit the screen ;)
I have a problem, it's difficult to conect wifi, and when conected, the ppc gets error,it can not work anymore unless soft reset. And when I use GPRS regularly, the phone signal is too weak,sometimes has no signal. I checked by turning off GPRS (use NO DATA software) the phone signal came back to normal.
when have incoming call,i see default theme, only have white theme with right is answer & left is ignore), not as your phone (green button answer & red button ignore) :-? have u have to setup 3rd soft ?
This is very strange I have run this rom and updated my emails from GPRS :-?? i really don't know what's wrong here ,Only thing i can think is Radio ROM not sure I will try to ask around :)
To make the slide to Answer work you need to turn it on in Smart Lock this software can be found in Settings\System you need to turn on INCall Lock when connected and incomming call lock then soft reset and it will now display Titanium lock screen like in the Pictures b-)
i use dopod 818,have problem when i start IE to use internet (already turn on wifi),after choice IE,my PPC is suspended,i have to soft reset it :( who can help me (T__T)
Are you saying your device í freezing after using IE ?
Have you tried a Different Browser ?
yes :D my phone is freezed after use IE :D,i haven't try orther browser because i already up ROM WM 6.5 build 23004 Titanium Neo Shadow WWE :D hehe
in ROM WM 6.5 build 23004 Titanium Neo Shadow WWE every thing is good,IE is ok,it doesn't make my phone freeze;)
có ai dịch hết các bài viết sang tiếng việt không? đọc không hiểu gì cả
chủ topic là người nước ngoài,họ làm ROM để chia sẻ,họ cố gắng dùng google dịch từ tiếng việt của mình sang tiếng Anh để họ hiểu và giao tiếp với chúng ta,vì thế với tinh thần giao lưu chúng ta nên dùng Tiếng Anh nói chuyện với họ :)
I use this here :
http://free-translation.imtranslator.net/English-language_Vietnamese-English_Translation
I share my ROMs here because this forum gave me some of the Best ROMs i have flashed on my phone and Lamson gave me the ability to cook ROMs so i try to share them here ,I don't understand all the Post's but i am trying to make the effort and be a part of your great forum community here :)
Thanks longak83for your kind reply and words :)
Thank Wapvirus for your sharing. In your topic we will try to use English Language. Many thank for Your Sharing & our members Support
