WM 6.5 build 23004 Titanium Neo Shadow PDA Viet Special Edition
I tried all your version roms and feel happy most of this version. Although it has some problems, but the speed and the interface is great. I hope you will soon release a new version of your further improvement. Thank you.
Thank you so much for the kind feed back i will make a new version but it will be older build as prophet has trouble with all the latest builds of 6.5
i can't connect wifi for o2 Neo , after wifi turn on , i click IE icon and my phone freezed ? Can u fix this problem ?
I also use this rom version and it still allows connect wifi normal. However, the wifi waves of my Prophet is very poor. it's speed not faster GPRS, and must very near to the host can connected. It's just to make scene :((
As i told before , i have a same problem.Can not connect Wifi, very difficult. If i try hard many times, i could connect but my fone was freeezed..
Excuse me, I want to have file .cab of "PCMKeyboard 1.4 Vietnamese QWERTY"
Can you share for me?
Thanks a lot!
MMS Could not Download nor Send
Hi all the PDA experts,
Anybody knows or facing the problem just as I found. I enjoyed using this RÓM, but only one thing still could not works until now :-/. My MMS always failed to download or to Send. It's already received in my MMS inbox but failed while downloading. It's seems missing first digit (0) Sender phone no.
Please advice guys.
Thanks in advanced.
Cái mà bạn hỏi với cái mà Lamson đưa ra chắc là một mà. Do nhầm lẫn chút khi viết v0.14 và v1.4
Bovovua ơi! Bản Rom này dùng thế nào hả bạn? Mấy bản của W@pvirus đều không tích hợp office mobile và pocketrar, thêm nữa mình cũng thích cái digital battery của Bikertibi...
Nếu bản 23004 này OK thì mình dùng luôn vậy.
Bovovua ơi! Bản Rom này dùng thế nào hả bạn? Mấy bản của W@pvirus đều không tích hợp office mobile và pocketrar, thêm nữa mình cũng thích cái digital battery của i...
Bản này dùng cũng khá ổn, mặc dù còn một số lỗi nhưng tốc độ tốt. Nó có tích hợp office đấy :)
Nhưng bản này cũ rồi, có lẽ ko tốt bằng mấy bản của Bikertibi :D
bản này xài rất tốt cho neo của mình,ít ngốn bin,ko bị tắt nguồn.nhưng bị lỗi mỗi lần khởi động lại là máy seach mạng hơi lâu (khoảng 2 phút).mình ko biết do bản radio hay gì nữa(mình xài radio 2.19),wifi hơi chậm...Nói chung bản này rất good(hơn hẳn bản 28008 mình đã test).
room nhiều lỗi quá, cảm ứng không chuẩn, explorer dùng không tiện. contact ko hiển thị ở today như hình trong threat(cái này có thể do máy). dù sao cũng thank.
