phobunmimien
bản 21-1 anh dùng có cài đc quick office ko ạ
Đã có bản MIUI 18.2 mới nhất với rất nhiều cập nhật:
Phone:
Added attribution to the database Add 5696 records, repair of individual error data
Repair failed will display the call duration of last call issues
IP phone repair attribution problem can not be displayed
86 at the beginning of the local repair will be resolved as long-distance fixed the problem
Repair data connection and try again the problem may lead to FC
Optimized default "call against misuse" switch off by itself without the user
SMS:
Repair in some cases the problem can not receive long text messages
Press Menu fix the content of messages will be truncated in some location problems
New SMS contacts fix drop-down list and set the input items "display only the phone number" problem of inconsistency
Receive multimedia messages to remind the repair is displayed when downloading time and not receiving MMS expiration of time to download
Edit mass repair call, the contact data changes in the call does not change the problem
Edit mass term fix, there is a strange error when the problem of contact
Optimization of the first loading speed when entering text
Optimization further optimize mass properties
Contact:
When repair is not bound account the problems the new group will be FC
Settings:
Repair the password change in the pattern set in the invisible problem of invalid
Desktop:
Optimization to improve the accuracy of the icon bar moving in the end
Optimized to press home to open "recent tasks" faster
Optimized for faster return to the desktop
Theme:
Optimization of the process to change the theme faster
Optimization of some additional effects of two-state button
Fixes can not back up the theme problem
Download failed mistaken for a successful repair problems
Lock screen:
Add the contents of the lock-screen message in the SMS preview function can be set to turn off
Music:
Add edit song ID3 information
Add related local lyrics, album
Add to manually adjust the lyrics progress
Add SD card music folder to rename, delete, and file the same name, deleted the playlist update
Add set to increase "does not use the system to provide album" option is to solve the system library problems associated with the error image
Several causes crash of bug fixes
Camera: (in MIUI network disk download)
Improve boot speed optimization
Widescreen fix some models of mobile phone settings initialization problem FC
Click the photo fix button to take pictures during the period of time will cause the camera does not respond to the problem
Gallery:
Add three sorting methods (menu key exhale): Created by file, by file name and by file size
Add the folder view in the gallery to add a menu option to manually trigger the SD card scanning
Fix the big picture enlarged ambiguous in the case of memory allows the maximum guarantee its definition
Zoom and move around after the repair is easy to switch to the next when the problem
Slide your finger to switch the picture optimization comparison card problems and improve finger movement for smoother zoom picture
Mấy bản miui này có gingerbread 2.3 chưa mấy bác? Hiện tại muốn lên 2.3 thì dùng bản nào? (không phải là miui cũng được)
Hướng dẫn cài bản 19.2:sao ko tìm được bản 19-Feb nào thế bác ơi
Em không dùng livewall, nên muốn xóa các file này trong máy thì vào đâu để xóa vậy các bác?
1. Download bản Rom MIUI 19.2 gốc tiếng Hoa tại đây
http://222.35.136.152/ota/miui-htcleo-1.2.19.zip
2. Download English Lang Pack 19.2 cho N1 tại đây
http://miui.info/markhuk/miui/N1/miuidev-1.2.19_N1-EN-PACK1.zip
3. Dùng Winrar mở Lang Pack, vào system mở file build.prop bằng notepad, thay đổi hết các chữ Nexus One bằng HD2 (nếu không thay thì sau khi flash trên máy sẽ hiển thị là Nexus One) hoặc có thể xóa hẳn file build.prop này đi cũng được
4. Copy 2 file ở trên vào thẻ nhớ
5. Khởi động lại vào Recovery, Wipe cache + Wipe dalvik cache (Wipe all data nếu không muốn giữ lại dữ liệu và cài mới 100%)
6. Flash bản MIUI gốc tiếng Hoa
7. Flash bản Lang pack đã edit ở trên
8. Reboot lại và kiểm tra thành quả
Nguồn miui.com và miui-dev.com
Thank bác!!
Down về xúc thôi
Bác nào test rồi cho mọi người vài dòng cảm nhận điHướng dẫn cài bản 19.2:
Cài titanium backup là xóa dc bác ui
Em cài rồi, ý em hỏi là xóa cái nào, app tên gì, vì em tìm ko thấy, sợ xóa lộn là toi. Hôm trước thay cái phone.apk nhưng bị lỗi fc liên tục không dùng được, phải dùng đến xảo thuật" mới chịu ok đấy
Thì xóa cái bạn cần xóa có tên tuổi là Live wall đó
Bạn cài đi rồi mới thấy dễ ;![]()
